Battery draining Issue
(Topic created on: 07-18-2024 04:49 PM)
atulx07
I'm totally frustrated with Samsung S23 battery. It's a flagship series of Samsung and It battery should be well optimized. Even if I'm not doing anything, battery still drain quickly. As you can see 18% drained only in 39 minutes of SOT.
I'll appreciate Iphone in this segment.
15 Comments
f62_CA
Expert Level 3
Is there any advantage of snapdragon...that u felt in daily life
atulx07
Yes it's running smooth. I'm not feeling any kind of lag while using my phone. Display, camera , performance , design and everything is good except battery.
atulx07
My phone has Snapdragon 8Gen 2.
Mr-RKS
I don't know why, but the battery drains a bit too quickly when talking on a call on Samsung phone.
mhdmuneeeeb
Same issue on my s23 ultra battery is worse after June Update 1721312277616.jpg
atulx07
But you are getting good SOT
Sameer
For battery drain pls refer to the below tips and tricks to enhance battery life
https://youtu.be/DXM7pdW5a-w?si=jPrtDBOtQwYdA3cO
Always make your phone run 2x faster
https://youtu.be/pgNi1Pmua3c?si=BSGl0-4vAexq9BmH
Subscribe to my channel for many more exclusive content coming up....
cs_member10
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps in the link below.
If the issue still occurs, please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
SachinDnl
Bro charge u r phone 100% than check
