Battery drain
(Topic created on: 05-17-2025 06:41 AM)
vincentset
After android 15 update on s23fe, phone's battery drains rapidly, please fix this issue
5 Comments
Manish0024
I'm also using s23fe and I perform heavy tasks daily
But i notice battery has improved
There is no major issue 👍
vincentset
Mine is dropped by 10 to 15% after the update
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
