Battery drain s20 fe 5g
(Topic created on: 12-26-2022 09:38 AM)
Akhil1111
Hi, has anyone noticed that s20 fe 5g has some battery issues recently, my device draining a little quicker than before after 20 days from A13 update, for just 50 mins of usage it dropped from 100 to 80 percent.
How can we fix this
3 Comments
ravi2407
Yes ..its draining fast
Akhil1111
Yeah
cs-member11
Dear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
