Battery drain problem after updating to One UI 7.
(Topic created on: 05-13-2025 12:01 AM)
H_HasanKhan
Battery drains faster after updating my phone to One UI 7
14 Comments
H_HasanKhan
Thank u ❤
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
H_HasanKhan
Okay, thank you for your time 🩵
goodthings
goodthings
Your's most welcome to here.
