Battery drain problem after updating to One UI 7.
(Topic created on: 05-13-2025 12:01 AM)
H_HasanKhan
Battery drains faster after updating my phone to One UI 7
14 Comments
abyyyymichael
whatsapp doesnt function properly in my s24 fe .what can i do about it
H_HasanKhan
I haven't faced this problem yet. You can check app permissions, ensure the app is updated, and if it's still not working properly, clear the app cache or data.
abyyyymichael
ive done all that
abyyyymichael
tried reinstalling too
H_HasanKhan
Are you facing this problem on One UI 7?
abyyyymichael
yep
abyyyymichael
H_HasanKhan
Wait for the next update; hopefully, these problems will be fixed.
JayaPrathap
It happens for any new software to a mobile, that's because the mobile hardware must adjust to the software Loaded and need some days understanding the usage patterns, consumption and optimising according to user needs and behavior.
So take some time use mobile in smooth way with less handling or keeping less pressure on cpu which gets settle for few days and battery problem also resets!
If it resolve your problem soon, accept and share my solution, thank you.
