Battery drain + overheating issue
(Topic created on: 03-23-2024 12:11 PM)
tanishrawat
I have recently updated my phone with the March security patch update, and I am facing overheating issue with my device and the battery life has also decreased by almost 1 hour. So I wouldn't recommend anyone to update their device right now as it has these major issues. Plus I would request samsung to provide S20 fe 5g with the one ui 6 update as it is last major update which is missing for this update.
7 Comments
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. Meanwhile turn off location when necessary open than close, stop all background apps also remove unused apps also put unused apps deep sleep or sleep mode,stop adaptive brightness, use 60 Hz.refresh rate of display, use dark mode. Always charge your's battery from 15 % To 85 %for long life and better performance. If you like please accept as a solution it's help to others users also, click 3dots in my reply section and click on accept solution. Thanks.
am100
Bhai sahab kuch din chutti lelo pls.
goodthings
Bhai sahab kuchh din apna bhi kaam karlo pls.
goodthings
Your's most welcome to here.
am100
Clear cache and repair apps.
mith37
Nothing works.. it's optimization issue
cs_member10
Dear Samsung Member,
As per your concern, we want to inform you that the issue could occur due to usage and various other factors, however, it is our best endeavor to provide you with an impeccable product experience at Samsung. Our products pass through rigorous quality checks which are globally recognized. And your device received all the major updates, so not it is not able to receive One UI 6.
For issues kindly follow the given steps to resolve your issue:
Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
Galaxy device battery drain issue:
Charge in one go instead of charging many times as it affects the life span of the battery and battery performance
Perform Battery Optimization
Settings > Select Device Maintenance/Device Care/Battery and device care > Optimize > Optimize all options like Battery, Storage, and Memory
Turn off Wi-Fi, GPS, Bluetooth, etc.
Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
Check device network fluctuation
Kindly check whether the mobile network fluctuates frequently or if the network signal is low in your area. In both cases, the battery will drain considerably fast.
Recommendation: We recommend you avoid using it in areas with low network/fluctuation.
Reduce display brightness level
Kindly set the device display brightness in auto mode (If available).
Adjust screen timeout settings: Settings > Display > Screen timeout > Select minimum screen timeout.
Check and update the App: Kindly check which application or interface is using more battery from device care. And try to update the app or avoid using that app.
Close background running apps
Close all the background running apps when not using them,
Turn off auto sync of e-mails, app data, etc.
We request you turn off the auto sync option, it will stop the synchronization of the device with the server & reduce the battery drainage.
The steps to turn off auto sync are:
2. Turn off the auto sync option.
Check your device in safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
