Battery drain issues
(Topic created on: 05-28-2025 08:41 AM)
vikky_01
Pehle to software itna late aaya ..aur aaya to battery drain issues saath laya..aur samsung walo ka koi update nahi aya abhi tak isko solve krne k liye..abhi oneplus ka 13s launch ho rha hai..sochta hu apna s24 plus sale krke op13s hi le lu ya xiaomi 15..kam se kam battery ka jhanjhat to khatam ho😁😁
8 Comments
Arit1011
😂😂😂😂samsung what are you doing,
Solve our problems,
"You’ve got the update, but I still haven’t received the Android 15 update."
vikky_01
Bhai nahi mili to achha hai..community check kro sabhi taraf problems hi hai..complaints hi bhare pade hai..scamsung naye phone bech rha hai..purane walo ki khabar nahi..tabhi to vivo oppo oneplus aage aa rhi hai..✌️
Arit1011
Akdom sahi bola😊
NeeluPkumar
Bhai lele oneplus 13s mast phone hai me bhi wahi le raha hu software battery display ik dim next level
vikky_01
Han bhai 5 june ko launch ho rha hai...ek month reviews dekh k decide krunga oneplus 13s lena hai xiaomi 15 ya oppo reno 14 jo mid july mein aarha hai
NeeluPkumar
Hmm
Vishaloza1112
Dear Samsung members,
It's our policy to scam people. We are working on it and will give you a solution in 5 to 6 years with updates.
If you cannot wait then you must buy our latest S25,25+ or 25ultra. Please give us one more chance to sacme you again.
Thank you.
From SCAM SUNG 😂
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
