Resolved! Solved
Battery drain issue
(Topic created on: 07-10-2025 09:44 AM)
_Anish___
So, after the One Ui 7 update my S23's battery drains so fast that I have to charge it twice a day. Earlier it was fine but after the update it got worse. So, I have to keep my refresh rate at 60 hz and I don't like to use my phone at 60 hz. Is anybody else also facing the same issue ? And can anybody suggest me any tips to reduce battery drainage ?
goodthings
Kindly complaint to Samsung customer care support through Samsung Members app as error report also send log files along with this error report for this issue and wait for next update maybe fix it by Samsung team soon. If you like please accept as a solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
3 Comments
goodthings
goodthings
You're welcome to here.
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next.
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tab on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
