Battery drain issue
(Topic created on: 08-30-2024 06:22 PM)
SijoRoy
Samsung Galaxy S22 Ultra latest update ONE UI 6.1 - Galaxy S22 Ultra (SM-S908E) is very smooth and better performance..but fast battery drain issue..plz fix it
5 Comments
goodthings
Kindly reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
Ramyaboda
It is happening on my s24 ulta too
Prashantbgh
Right...severe battery draining issue in my s22 ultra.. but Samsung still unable to solve it yet. Yes you are right ️ that the animation and overall performance is very smooth like butter but battery draining severely..Samsung can solve this issue but they are busy with their latest phones which gives them profit.
cs_member10
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
