Battery drain issue on my s21 fe
(Topic created on: 05-14-2025 10:31 AM)
bhupeeb
The Battery is draining faster after the one UI 7.0 update.
5 Comments
Not applicable
Bro like how frequently.mine is working fine like I didn't get this much battery backup before.
Ramkrushna259
Yes its battery is draining little faster than before and its heating frequently.I think it need a little bit more updates to fix these problems.
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
goodthings
goodthings
Your's most welcome to here.
