Battery drain issue in s24 after ONE UI 7update
(Topic created on: 05-02-2025 01:31 AM)
gourabdas99
Beginner Level 4
Battery draining is much faster in normal and even in power saving mode after ONE UI 7 and android 15 update in s24
Also showing the huge shutter lag in main camera..
Please solve the issue..
5 Comments
blazeee
I agree with you I even got the s24
Niranjan1988
Yes I will same issue with my S24Fe
cs_member10
Dear Samsung member,
Galaxy device camera issue: 1.Clear camera app data: Settings > Apps > Camera > Storage > Clear data.
2.Remove the third-party apps: Settings > Apps > Select the third-party App > Uninstall.
3. Reset the device:
IMPORTANT:
• For this:
goodthings
goodthings
Your's most welcome to here.
