Battery drain issue in s23
(Topic created on: 06-30-2025 11:09 PM)
honey8088
Only getting 2hours 45 min sot in 5g 120hz refreshrate
And 3. Hours 20 min sot in 40 60hz
My phone is 2 years old, should I change the battery or this is update issue pls
Write your sot s23 users
32 Comments
cs_member10
Dear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
goodthings
goodthings
Your's most welcome to here.
