Battery drain issue after oneui7 update
(Topic created on: 05-02-2025 11:40 AM)
Lōgan
Anyone else facing battery draining issue after oneui 7 update ?
6 Comments
Mishuwski
Yes! I instantly lost 1% charge right after plugging out from charging consistently since the update. Also, my phone heats up a lot. I have to charge my phone 2-3 times a day whereas once would have been sufficient before. I'm using S24 Ultra btw.
salmusalim
Yes
goodthings
goodthings
Your's most welcome to here.
mahtab1900
Yes me too getting
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
