Battery drain issue S21 FE model ( Snapdragon 888 version)
(Topic created on: 10-14-2023 09:06 AM)
PankajKamthe
Dear Samsung,
I have bought Samsung s21 fe (snapdragon version) 3 Days back and expecting to have good battery life but it looks like it has battery drain issue automatically.
1st Instance = I had 99% of battery charging in the night 11 PM IST and at 6 AM IST in the morning, It was 93% and internet was totally off but still battery charging got dropped to 7% which seems quite huge. Compare to another phone model (Vivo snapdragon 778g), Samsung is draining more than 5%.
2nd Instance = Another live example is while writing this problem statement battery drained 4%. I spend 15 mins and theme is dark and battery brightness is below 20%.
BATTERY DRAINING ISSUE BIG PROBLEM PLEASE CONSIDER THIS AS HIGH PRIORITY PROBLEM AND SEE IF YOU CAN FIX THIS PROBLEM.
Thanks,
Pankaj Kamthe
21 Comments
Sáyân15
It's obvious for a new device to drain battery higher than usual. Let the OS get familiar with your usage patterns. After a week or two, you'll get good battery life...
If my information was helpful then do accept this as solution 🙂
SamualAnok
My battery drain faster,battery health only 13 hours Please samsung do optimize my s21 fe snapdragon 888.
DhruvDeshoande
Beginner Level 4
Same
fezzan
Bro iam using s21 fe for last 8th months and it's battery drain like water. I went to the service center and they told to update my phone, but after the update it's battery still drain like before.
AGalaxyuser
Same issue I'm facing. Mine dropped 3% at night. Backup is less compared to my M32,M20. They are still giving me 7+ hours sot whereas S21 fe giving me 6hours sot in average. Don't use 5g and turn off adaptive battery
souravsrv1176
I had also face this issue initially. But it settled down after few days...
sudanagunta
Same problem I also faced speed battery drain problem in s21fe
iadcy88
Forward to samsung
ImtuBarua
Maybe some software issues. Try to update the latest software of your device
