12-21-2024 07:24 PM in
Galaxy S- Mark as New
12-21-2024 07:33 PM in
12-21-2024 07:51 PM in
12-21-2024 08:44 PM in
12-23-2024 12:08 PM in
Galaxy SDear Samsung Member,
We regret to hear about your experience with our product.
To fix battery drain issue please use the link to perform some easy troubleshooting steps: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps:
3. If you do not remember then reset (Forgot password) your Google account.
If the issue still To share a log file, open Samsung member application >> tap on support >> tap on send feedback >> choose composer option >> select error >> select the appropriate category >> type your query
