08-08-2024 06:44 PM in
Galaxy S- Mark as New
08-08-2024 08:49 PM in
08-08-2024 08:50 PM in
08-09-2024 08:51 AM (Last edited 08-09-2024 09:13 AM ) in
Galaxy SDear Samsung Member,
As per your concern, we would request you to kindly perform the following steps to resolve your issue. However, we are taking your valuable feedback regarding this.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
08-09-2024 10:47 AM in
08-10-2024 07:48 AM in
Galaxy SMaking the following changes as shown in the video ...wait for few weeks for the phone to study the usage patterns and you will see an improvement in battery life
https://youtu.be/DXM7pdW5a-w?si=cXv4W6zVL3JvVBqp
Also make your phone run 2x faster.
https://youtu.be/pgNi1Pmua3c?si=HvJhiGglU77saHG9
08-10-2024 09:33 PM in
08-16-2024 07:38 AM in
