Resolved! Solved
Battery drain and one ui 7 update issue.
(Topic created on: 07-06-2025 10:52 PM)
zayedbd77
My device S23 Ultra, after updating to One UI 7, is draining a lot of battery. Will this be fixed in the next update? If anyone knows, please help me. I am a Samsung lover but it is difficult if it happens like this.
goodthings
6 Comments
rushisakpal
Turn on deep sleep option and put performance profile on light mode
hpsingh75
If this is the solution then Chinese brands are better 😂
rushisakpal
This will optimize your device and this will not affect your devjce performance. Your unused app will be in deep sleep. Try for 2 days then see
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next.
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tab on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
Hamzaulde
If you're suggesting to perform steps from 1 to 8 for flagship phone like S23 Ultra, then I'm not sure what's the use of buying this much expensive phones. Samsung should provide the fix via software update as soon as possible as we need to charge phone twice then usual single charge earlier.
It should've been fixed by now. Not sure if Samsung Community is focusing on customer responses and reporting it to Samsung developers.
goodthings
