Battery drain and network fluctuate
(Topic created on: 10-26-2024 01:18 PM)
karimuls23ultra
Beginner Level 4
Heavily battery drain and switching every time from 4g to 5g and 5g to 4g
6 Comments
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
Rvira
You need to optimize the things in phone bro.
Search youtube,
you are the owner of your own.
Gather information online,youtube Before going for samsung support.
Thanks.
cs_member10
Dear Samsung Member,
As per your concern, we want to inform you that while 5G devices work with both LTE and 5G networks, they may consume more battery and generate more heat compared to LTE devices. High-speed processing for heavy data can lead to increased energy usage and device heating. If your device gets too hot, our safety algorithm may limit performance and switch to 4G temporarily to prevent overheating. This is normal and helps maintain device performance.
In this case, please wait for the device to get cool down for a while and then use the device again. If the 5G device gets cooled down to a specific temperature, the device will connect to the 5G network again.
However, kindly perform the following steps to resolve your issue by using the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
You can reset your device by following the steps.
JithinAjith
Settings 》Google 》Devices 》Turn off scan for nearby devices
Settings 》Connections 》More connection settings 》Printing 》Turn off default printing service
Device care 》Battery 》Background usage limit 》Deep sleeping apps 》 add apps
Settings 》Location 》Improve Accuracy 》Turn off Bluetooth and WiFi scanning
