Battery drain and excessive heating issue in S23U after OneUI7 update
(Topic created on: 3 weeks ago)
iamvishique
Even just 10 minutes pf scrolling in instagram or streaming YT or Prime video is heating the screen and back side of the phone. Is this a feature with the update or something? Im really dissappointed with ONEUI7
6 Comments
BiRdMaN
ShAMeSUNG will fix it in the next security patch update
iamvishique
I hope so man.. its really frustrating. Even in idle I could feel the warmth pf my phone.. its that bad
goodthings
goodthings
Your's most welcome to here.
sarfarazahmed
I do certain things it help me
1st clear cache
2nd dial *#9900#
scroll down u will find battery reset tap that
3.install galaxy guardian and galaxy app booster from google chrome coz u wont find in galaxy app store
Run to optimize apps and u will
see some difference
Then restart ur phone
Charge it till100% and then use it
cs_member10
Dear Samsung member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
▶ Galaxy device Battery drainage issue: Note: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
2. Check device network fluctuation.
3. Adjust screen timeout settings: Go to Settings > Display > Screen timeout > Select the minimum screen timeout.
4. Check which application is or interface is using more battery from device care and try to update app or avoid using that app.
6. Turn off auto sync of e-mails, app data etc.
▶ Galaxy device heating issue: 1.Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
7. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
8. Reset the device:
IMPORTANT:
• For this:
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
