01-27-2022 04:35 AM (Last edited 01-27-2022 04:37 AM ) in
Galaxy SHi my s10e after the UI4.0 my battery last 10h if i leave the phone in standby...in normal use last around 4-5h...did cleared cache...restore to factory settings.. all tips used to save battery ,no always on display ,no sync ,etc...I'm using my phone like in 90'...should i put it on airplane mode? 😁😅 i need help
01-27-2022 06:16 AM in
Galaxy S- Mark as New
01-27-2022 07:30 AM in
Galaxy SPls try standard refresh rate and use for one day
It will stay one day
Same result for a52 also
01-27-2022 07:22 AM in
01-27-2022 07:35 PM in
02-09-2022 04:35 PM in
Galaxy SDear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
02-11-2022 09:46 PM in
