Battery down
(Topic created on: 09-20-2023 10:40 AM)
SAEEDKHALIFA
September security update battery down issues 23 ultra ma
cs_member10
Dear Samsung member,
Kindly follow the easy troubleshooting steps which might help to solve the issue.
Battery life depends on how the battery is used. Note that different devices have different battery life. The expected battery life for your model can be found in the manual.
Kindly perform some quick troubleshooting steps to resolve your issue:
Please always use a standard charging procedure. Always charge in one go instead of charging many times as it affects the life span of the battery and battery performance.
Perform Battery Optimization: Battery optimization helps you to boost the battery performance of your device. To check battery optimization:
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Turn off Wi-Fi, GPS, Bluetooth etc.
Turn off unused functions like Wi-Fi, GPS, Bluetooth & Location settings when not using them.
Please follow the below steps:
Step1: On the home screen swipe down the notification panel.
Step2: Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
Check device network fluctuation
Kindly check whether mobile network fluctuates frequently or network signal is low in your area. In both cases battery will drain considerably fast.
Recommendation: We recommend you to avoid usage in area with low network/fluctuation.
Reduce display brightness level
Kindly set the device display brightness in auto mode (If available).
Steps for setting display brightness in auto mode:
Swipe down on the home screen to open notification panel
Turn on Auto brightness option if available.
It will automatically adjust the display brightness of your device according to ambient light & will reduce the battery drainage.
Adjust screen timeout settings
Note: Steps and Images may vary according to OS.
Step1: Navigate to apps screen and tap on Settings.
Step2: Tap on Display.
Step3: Tap Screen timeout.
Step4: Select minimum screen timeout.
Check and update the App
Kindly check which application is or interface is using more battery from device care. And try to update app or avoid using that app.
Close background running apps
''Multiple applications'' are running in the background of the device?
When running multiple applications, the processor processes more tasks and as a result, additional heat is released from the device. This happens with most electronic devices (even computers/laptops), including the devices of other manufacturers. Close all the background running apps when not using them,
How to close:
Tap on recent key and close the background running application.
Turn off auto sync of e-mails, app data etc.
We request you to turn off the auto sync option, it will stop the synchronization of device with server & reduce the battery drainage.
Steps to turn off auto sync are:
1.Swipe down on the home screen to open notification panel.
2.Turn off auto sync option.
Check the device in safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
Perform software update (If available)
Ensure stable Wi-Fi connection to your mobile. Downloading via mobile network may result in additional charges.
Please ensure enough storage space in your device.
Please ensure your device has sufficient battery for updating software. (above 50%)
1. Navigate to apps screen and tap on Settings.
2. Tap on Software update.
3. Tap on Download and install.
4. Checking for software update.
5. Software update available.
6. Tap on Download.
7. Downloading updates.
8. Tap on Install now.
Reset the device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Warm regard,
