Battery deterioration
(Topic created on: 10-04-2024 04:47 PM)
Drax55
Recently I got battery deterioration warning and changed battery from service center, even after that I got warning again and in diagnostics showing as battery life weak
6 Comments
mubzzzz
There might be some issues with the phone's motherboard.🙏
Bhardwaj2678
There might be motherboard issue or software issue, you need to visit to the service centre again
iamrohitkm
It usually happens, it seems I have inquired with the service center they told even after changing the battery this warning comes it seems don't worry much
cs_member8
Dear Samsung Member,
As per your query, we would request you kindly visit the service centre once again from where you have done the service of the product earlier and inspect your device with the technical team end, they will provide you with all the information in a better way after inspecting the device physically.
anichet
बैटरी को दुरुस्त करने का क्या उपाय है बता सकते हो क्या मेरे फोन की 6000 mh बैटरी होने पर भी पूरा दिन नहीं चला पाता हूँ आपकी सेमसंग कंपनी का नाम ईतना होने पर मेने फोन लिया है पर ऐसा होने पर तो विश्वास ही उठता जा रहा है, कृपया उचित समाधान बताएँगे क्या 🤔🤔
anu_shetty
Battery is not stable
