Battery backup on cellular mode
(Topic created on: 10-08-2025 05:29 PM)
kunal5
The battery backup and standby time on Galaxy S25 Ultra in cellular mode is the worst. Even if I don't use the phone, it drains too much and when I start using it in cellular mode, the battery percentage drops 3 to 5 percent within 10 minutes. Not the kind of performance you expect from a flagship device.
2 Comments
Shivamwalia9
Yes in s24 ultra same problem facing I'm
cs_member10
Dear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• If you do not remember it, then reset (Forgot password) your google account.
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
