Battery backup in Samsung Galaxy S20 FE 5G
(Topic created on: 03-01-2022 08:33 AM)
Ramprakashprmurali
Can anyone tell me if this is normal or is it draining fast?
öNonMonkö
Have a look at the battery performance on my S20 FE. It was recharged until one hundred per cent and subsequently recharged at seven per cent.
Please keep in mind that my S20 FE is not more than a week old.20220302_190401_4278_1646228042.jpg
Could you please share the app-wise usage if possible? Also is it 120Hz?
öNonMonkö
Sure. Please see the attached screenshot. The refresh rate is set to 120Hz.Screenshot_20220302-041811_Device care_4246_1646174914.jpg
abbyzy
The battery drainage has increased tremendously after one ui 4.0 update with Android 12 in s20 Fe 5g
Kindly fix the software and UI which ic causing battery drainage.
Earlier I used to get 1.5 days of usage but now with same usage I am getting less than 1 day of battery life.
I bought the smart phone in the month of September 2021
I hope we'll have to wait for a fix from Samsung in the next update.
abbyzy
I think they(Samsung) are least bothered about the issues consumer are facing in previous version of smartphone.
Nowadays all manufacturers really want is to sell new smartphone everymonth
So here's an update on the battery backup. Will wait till this weekend and check with the service center.Screenshot_20220303-220721_Device care.jpg
Devam_Jani
How it improved???
Not improved at all. The screenshot in the post was with 85% Battery level and this comment was with 100% battery level for charging. I'll wait for a day again and check if things are really good.
