Jigs1987
05-19-2024 12:43 PM in
I have s23fe my battery drain too fast and phone heats
5 Comments
Abhay010101
05-19-2024 12:57 PM in
Me also in a54
HarshaKarn
05-19-2024 01:24 PM in
See its summer time so almost every phone face this problem. I think you have bought your phone in winters so there is no big deal with the heating issue.
And about battery drain you should clear chace files from boot menu once after update or after 2 - 3 months.
To do so
1. Connect you device to and pc or laptop device with cable and turn off your phone.
2. Press Volume UP button and Power button simultaneously and release after vibration.
3. Go to wipe cache partition then go to yes. Using volume buttons to select and power button to enter.
4. After that go to reboot and press power button.
I think this will fix your problem.
Or
You should report this through members app about your problem and they will suggest you best settings and care tips to fix this problem
To do so
Or
goodthings
05-19-2024 07:43 PM in
Kindly reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution . Thanks.
goodthings
Your's most welcome to here.
Mr_Riyaj
07-30-2024 03:59 PM in
I recently bought the S23fe model . As soon as I got the phone I updated it in 6.1 ui. I am also facing the heating issue in my new phone
What should I do now
