Battery Replaced but Still shows Weak battery in Diagnostics
(Topic created on: 06-20-2022 09:51 PM)
Not applicable
I got the battery on my 3 year old galaxy S10 replaced from Samsung Care Centre, Jalandhar. When I came home, the battery still shows as "weak" when I ran the diagnostics.
39 Comments
Sid_Karna
That might be based on the old data. Check again after a couple of days.
Not applicable
Does it reflect old data even after I have run a factory reset ? Thanks for the reply, btw.
secretmanraj
No
Sid_Karna
After a factory reset, it shouldn't show old data as all such data is supposed to be deleted.
Gaurav_Sîngh
what was the cost of battery replacement?
Not applicable
₹2024.
Kunal2
What about battery backup then. Incresse or the same
Not applicable
Looks like it has increased a bit. BUT I think it will get better as I charge my phone again.
