Battery Issue
(Topic created on: 10-13-2023 03:08 PM)
mayurmadhwani
I updated my S21 FE to September Security patch and the battery backup has become really poor.
Battery drops even on standby.
Really disappointed.
7 Comments
Are you using Exynos varient
mayurmadhwani
Yes
What is happening with samsung my sd 888 varient is overheating and no update.its security patch is August.
seionlopez
Yes it is over heating
seionlopez
Yes
I had also the same problem
Will they fix it
cs_member10
Dear Samsung Member,
As per your concern, we would request you to kindly perform the following steps by a given link to resolve your issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Update device software (If available): Settings > Software update > Download and install > Checking for software update > Software update available > Download > Downloading updates > Install now.
You can check the device in safe mode and for the same mode you can tap on the given link. https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
We have noted your valuable feedback, We are continuously working to make our products better and more efficient.
In case the issue still occurs. Please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
