Battery Issue
(Topic created on: 09-26-2022 03:55 PM)
Banner_
What is the normal battery backup after a full charge of Samsung Galaxy S21 FE 5G..?
Can anyone please share it will be of great help.
I have recently purchased my device and the battery goes down to 50% in just 3hr 30 mins of screen timing.
7 Comments
EthanHunt24
Exynos is always a power hungry chip.. Mostly it will give only 5hr moderate usage...the ideal draining is too much..
Banner_
I used Samsung A50 too but this was not the case in it, cause it had also the exynos chipset
S21FE2022
A50 is a mid tier device, it's hardware is less powerful and hence less power hungry!
Mr-Rhino
With 120hz 5~6 hrs, 60hz 6~7 hrs of screen on time.
SamPro
It will take time to settle. As you have just purchased, give it some soaking time for a week or so. Then the phone auto manages the battery according to usage.
S21FE2022
This is the best you'll get, total 6hrs-7hrs max! If you want 8-10 h hrs you have to buy midrange phones with less powerful processors and more battery capacity. No flagship of high end mobile companies gives more than 6-7 hrs of screen on time!! People also criticize the slower charging speeds, but fail to understand that it affects battery longevity if it charges at crazy speeds.
HariharanNV
4 and half hours (100 to 20%) S21 FE
