Battery Issue In S24
(Topic created on: 08-18-2026 04:26 PM)
Ansh20041
I received only 4 hr of screen on time and my screen off time is 11 hr how to reduce screen off time i already putt alll the unnecessary apps in deep sleep mode is this normal Or conecrning?? I don't use any high end app
Suggest Me something
3 Comments
Ansh20041
10 months old only
bhghwan
Uninstall then reinstall first two apps
cs_member10
Dear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
