Battery Draining fast on s10 plus after Android 11 upgrade
(Topic created on: 01-23-2021 12:50 AM)
AshwinPatt
My battery is draining like hell on my s10 plus after upgrading to Android 11 and UI 3.0.
Any idea how to fix?
66 Comments
Ehsank
just for e.g. see attached image and determine yourself, you need those notification from Google and see another image and think you want battery consumption even you disable that option?
Ehsank
and wait for further update
TomazDrnovsek
I will do what you suggested but based on everything I wrote I have a feeling this is just going to be a waste of my time. All those functions were working fine before the update. All I'd like to hear is that Samsung knows about the issue since I'm not the only one with it, far from it, and they are working on the fix. I'd be happy to wait for the February patch and not waste my time chasing shadows if I'd knew the issue will be solved shortly.
Ehsank
TomazDrnovsek
So, I tried what you suggested but nothing really helped. I also waited for the patch which didn't solve the issue at all. I had no other choice than to do a factory reset.
This solved the issue. Now I'm back to normal battery consumption.
But I'm really not happy about this. I had complications with my banking app. I needed to activate the app again which involved going to the bank, waiting 5 days to get the code via mail, and all other unnecessary **bleep** involved with this just because I had no other option than to update and then no other option than to do a factory reset because I highly doubt Samsung or Google will solve this issue in any patch. People with this issue probably have no other option than to wipe their phones. That's just wrong on so many levels. Ok, I'm done here, for me it was solved but I do feel for others who will be waiting forever and charging their phones 2 times per day and practically not using them at all. Bye!
Guttie
Did they ever fix the issue?
I had to roll back my phone to the previous version and **bleep** it so it won't auto update.
But I can't find anywhere on the internet if it was ever fixed.
Ehsank
and very soon you will get an update to fix it till then try above steps
AshwinPatt
Tried the above steps and as well as did factory reset..no much improvement...let's wait for the stable version...
Ehsank
pradeepky
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
