Battery Drain So Fast
(Topic created on: 01-08-2021 01:07 PM)
vasimsaiyad
Dear samsung my galaxy s20fe battery drain so fast i bought this phone on 19-12-20 my phone is very new but battery drain so fast and i am a normal user like some time play YouTube and whatsapp elsewhere i am nothing doing anymore please solve my problem as soon as possible
8 Comments
Iamabhisingh_
maybe some bugs are there wait for the next update..might they will fix this issue..
vasimsaiyad
Not applicable
try these settings... it worked for my A70..
Hi guys,
Just yesterday I posted about this issue and I got a very helpful comment from a user called IcyJay and he advised me to do the following settings and I did as he said and today when I got up I had just lost 1% of my battery which used to drain about 5% overnight.Here are the steps to follow if youre facing the same problem despite setting off your background applications,mobile data,wifi,gps etc before going to sleep.
Here are the things you can should do -:
1 Turn off wifi and Bluetooth scanning
2 Turn off auto wifi hotspot.
3 Turn off wifi on automatically
4 Turn off auto optimise and settings. (Force closing apps do more harm)
5 Go to permission manager-> location-> show system apps and select 'allow location only when app in use' for all apps individually
6 Go to google from setting -> on device sharing -> remove 3rd party apps except google apps
 7 Again google -> device connection-> turn off nearby share, devices, cast media control, android auto
 8 Turn off auto update from both play store and galaxy store.
 9 disable these bloatwares-> appcloud,discover,samsung visit in, my galaxy.
10 Put galaxy themes in deep sleep.
Also apart from this make sure your phone is kept at a location that has the least dbm because the higher your network will stress to find coverage the higher will be the drain.If your SIM is finding hard to get coverage try getting SIM of a network that has great coverage in your area and you can monitor the dbs status in Settings--> About phone--> Sim Status.
Less than 90 dbs means your network will consume least battery and more than 90 dbs means higher consumption of battery due.
Thanks to IcyJay for helping me !!
Notadeveloper
120hz and exynos 990 not optimised well on Fe are the reasons. Fix wait for Samsung to fix it through ota. If you want more battery life switch to 60hz( i don't recommend coz its slow)
Ehsank
one of the main reasons of battery drain is background activity,
even you close apps but they uses ur battery and running in background unnecessary, see image(1) and read the statement.
2nd due to huge notification options.
for e.g ; Google has huge notification which we don't need at all see image(2) just scroll up and down and check how many notification it does have.
So do these settings to stop, which consume battery unnecessarily.
1. Settings>>Connection>more connections settings> disable nearby device settings
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
Ehsank
Besides above settings do some more settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> then go to these 3 options below on by one
5. Go to settings> privacy > permission manager > location> and check which app have accessing your location all the time and if not using that apps then deny access or set as " allowed only while in use"
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> account > checkwhich app syncing automatically there and if any app which not necessary to auto sync then click on it and disable sync.
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
KrishnaKD
hope Samsung do something for battery drain soon as most of d settings i did suggested by members but with POWER SAVING MODE ON+ without network connection on+ zero Screen on time battery drain from 100 to 90 i.e 10 percentage
cs-member13
Expert Level 4
Dear Samsung Member,
Please be assured and to resolve "Battery Drainage" issue kindly follow the given below step:
>>Battery optimization:-Settings>Select Device Maintenance/Device Care>Optimize>Optimize all options like Battery, Storage and Memory
For more information on battery drainage please click on the link below:
http://www.samsung.com/in/support/skp/faq/1101689
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
