Battery Drain Problem
(Topic created on: 09-13-2020 01:17 AM)
NoAlSm
Galaxy S10+' Battery is draining fast after One UI 2.5 update.
Is anybody facing same problem????
9 Comments
Not applicable
flash that firmware from service center or by Odin if you know the proper process.... if you simply updated it via mobile data or wifi then this is not process to install any big os or new ui interface as there is chance to produce software loop hole which produces this issues only if that software not installed fully or correctly...so flash it and enjoy the performance 😎😎👍
NoAlSm
Ehsank
try these settings to save more battery life if you not yet try
and observe for next 1-2 days
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
3. Google >click on 3dot>usage and diagnostics >off this option.
4. Long press on each app specially 3rd party(LIKE FACEBOOK, INSTA,YOUTUBE) and rarely used and ON "GOOGLE APP" as well then click on>app info> then go to these 3 options below on by one
5. Device care>battery >power mode>select "optimised" and "adaptive power saving".
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
6. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder.
7. If you use Facebook frequently then disable "auto play video"
And if you are mostly uses mobile on wifi connection then also disable "auto play videos" in YouTube.
NoAlSm
Thanks 👍
Ehsank
and if my given settings/comments will work for you then you can accept as solution by CLICKING on 3DOT at my comment.
Not applicable
After a major update battery stats get reset. It takes atleast 3 to 4 charge and discharge cycles to generate new battery stats. So wait for a bit. Battery will improve with time.
Try disabling Google App. My system Standby has increased by 10-15% at disabling Google app. Also play services is another culprit. There is little control over this but install Gsam battery monitor and check
cs-member13
Expert Level 4
Dear Samsung Member,
To resolve battery issue kindly follow the below given step:-
- Battery optimization:- Settings > Select Device Maintenance/Device Care>Optimize>Optimize all options like Battery, Storage and Memory
For more information on battery drainage please click on the link below:-
http://www.samsung.com/in/support/skp/faq/1101689
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question). Kindly send us the screenshot (which apps are consuming most of the battery).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
arunnechlani
