Battery Drain Issue After One UI 7 Update
(Topic created on: 05-01-2025 03:51 PM)
soumodeepnan
Hi Samsung Team,
After updating to One UI 7 on s23, I noticed a significant battery drain issue. Specifically:
• One UI Home seems to be consuming more battery than usual.
• The Always-On Display (AOD) is draining approximately 3-4% of the battery daily, which seems higher than expected.
These issues are affecting the overall battery performance, and I believe some optimizations could help resolve them.
Please consider addressing these in a future update. Let me know if there are any recommended fixes or workarounds in the meantime.
Thank you for your support!
3 Comments
goodthings
It's a major update reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
