Battery Drain & Heating Issue After May Update – S25 Ultra
(Topic created on: 3 weeks ago)
OyeeAbiee
Just wanted to check if anyone else is facing this. Back in February and March, my S25 Ultra used to last a solid 7 to 8 hours on a single charge, even with regular use. But ever since the May patch update, the battery life has dropped drastically – I’m barely getting 4 hours now, and that’s without any heavy usage like gaming or video editing.
Along with this, I’ve noticed the phone heats up quite a bit even during normal tasks like browsing or using social media.
Is anyone else experiencing this? Any workarounds or fixes that helped you?
You can see system UI itself taking 10% of battery for less than a min
10 Comments
S_Kumar73
Yes. May update spoiled S25 ultra battery life
OyeeAbiee
they had to push an update to fix this 🥲 ...Now it feels like I’m rocking a 2000mAh phone from 2014 just missing the removable battery and we’re golden
Timothy2
Expert Level 4
AmanRaghav
Happening with my S25 also... same issue
goodthings
goodthings
Your's most welcome to here.
shehz23
Facing exact same issue in my S25 ultra
cs_member10
Dear Samsung member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
▶ Galaxy device Battery drainage issue: Note: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
2. Check device network fluctuation.
3. Adjust screen timeout settings: Go to Settings > Display > Screen timeout > Select the minimum screen timeout.
4. Check which application is or interface is using more battery from device care and try to update app or avoid using that app.
6. Turn off auto sync of e-mails, app data etc.
▶ Galaxy device heating issue: 1.Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
7. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
8. Reset the device:
IMPORTANT:
• For this:
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
rage_knight
Beginner Level 3
Bonkers accept the fact that the may update is causing this issue, everywhere i see you guys are giving the same response
I'm paying 70k for a phone only to have battery drain issues after 3 months, what are your engineers even doing, this is such a major bug and on top of it not even acknowledging your mistake
