Battery Charging
(Topic created on: 09-14-2024 06:18 PM)
sswapon
What is the difference between Battery fast charging or normal charging?
Does normal charge drain slowly?
Or
Fast charging drain fast?
Or
Fast chaging occupied for battery long lasting?
Pls let me know.
Regards
4 Comments
Ak_Rocks
Normal charging. vs. Fast
Less heat generate More temp
Battery healthier 🔋 health drains
Low ele. Consumption High Consumption
No difference in battery backup !! 😉 please provide a follow
sswapon
Once u told low consumption, again said no difference in battery backup!
Zaiddmn
Fast charging and slow charging doesn't matter in latest smartphone devices. Don't worry 😉
cs_member10
Dear Samsung Member,
As per your query, we want to inform you that Fast charging significantly reduces charging times compared to normal charging. While normal charging may take some hours to reach a full charge, rapid charging can replenish a considerable percentage of the battery in minutes. However, there is no issue with battery performance with the charging, it totally depends on the usage of device, usage of the battery is different for every application, some apps consume more battery depending on the screen time, network fluctuation, refresh rate, etc. We always suggest to use fast charging to charger the device.
