Battery Backup Issue
(Topic created on: 11-06-2025 11:22 PM)
Wracker3700x
Greetings everyone,
Since i updated my Samsung S23 Ultra to Android 16 i'm facing battery backup issue. Drastically it reduced my backup. When i went to service centre i saw many people queuing of same issue battery backup reduce. The service centre person said that its a common issue of every person after updating to android 16. Is it true or should i change my battery.
11 Comments
cs_member10
Dear Samsung Member,
We have highlighted your concern to the dedicated team for further discussion on the case. They will contact you as soon as possible. You are our valued customer and we appreciate your patience in this regard. We assure to provide you with the resolution as per the Samsung guidelines.
Wracker3700x
Please help me whether should i change it to new one or not. If after changing to new one same backup if i get then it will be worse for me.
shaikhbilal67
I am also facing the same issue
Wracker3700x
I'm now in big trouble with this phone.
Same with my new s24u, previously getting 8hrs+ sot now hardly getting 6.5hrs
Wracker3700x
8hrs+ full charge?😮
Yes
Wracker3700x
That's very less backup. What's happening with samsung why backup dropped so drastically. Now i had to plan for something mid range phone which gives long backup. Now i'm waiting for Xiaomi 17 Pro Max. I never expected samsung to be so much power hungry.
