BATTERY REPLACEMENT MESSAGE
(Topic created on: 05-19-2022 09:02 PM)
Sunny0098
I recently got a notification on my Samsung(S10plus) smartphone that my phones battery is in poor condition and need to be replaced. I also use diagnostic it showed same that my battery is poor.
So I went to the Samsung Service center and I replaced my battery and then I immediately tried to run the Samsung Diagnostic again but it showed the same message again, that my phone battery is weak.
7 Comments
iamrohitkm
Try again and check it shouldn't come.
Sunny0098
I did check that 2 times And I also charged the new battery to 100% and restarted my phone still it showing battery status weak
ㅤ
if someone use original charger.
use phone correctly.
how can a battery health get weak... ? actually it might be a new trick from companies to make users spend more money on their device.
Sunny0098
I don't know about it how it happened but my phone is already 4 years old now and this was the first I had to replace my battery.
ㅤ
time dsnt matter.. battery is just a battery.
if phone is saying battery health weak.. tht dsnt mean its realy weak.
first please tell how much it goes.. . i mean how much time it takes to get low. .. (battery sot)
Sunny0098
Before it was reducing very fast after the phone reaches 85% then I use it normally and it used to get 80% with just scroll in the phone and if I use to play a game even in powersaver mode it started to heat up and it reduced around 15 to 20% (1 match of bgmi). Now today I changed my battery it is working okay not getting heat or not even draining fast its just when I use diagnostic then it shows battery is weak.
cs_member8
Dear Samsung Member,
We acknowledge your query and apologize for the same. We request that you kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
