BATTERY DRAIN IN S23 ULTRA AFTER ONE UI 6
(Topic created on: 11-05-2023 12:02 AM)
KD91
Sharing few screenshots to show my unusual battery drain of my S23 ultra after the one ui 6 update. I charged my phone till 85% which I usually do and before this update, I used to get approx 5 hrs 15 mins SOT when I reach 30% mark with my kind of usage. But after the update, when I reached 30% mark, I just got approx 4 hrs SOT ( Note- THE SCREENSHOT IS SHOWING 4 hrs 56 Mins SOT, BUT 1 HR SOT IS FROM LAST CHARGE, AND 4 HRS FROM CURRENT CHARGE). So, I got just 4 hrs SOT by using 55% charge. Approx 1 hr SOT has got reduced after this update. Now, people will jump and recommend to do this and that to improve my backup, my question is why should I ? Earlier also, I used the same settings and used to get better SOT, then just to hide the actual fact, why should I change my settings to improve when the problem is not with my usage rather it's with the update and the SAMSUNG guys should acknowledge this.
So, if any Samsung people is seeing my post, my request is that please come up with an update which fixes these issues ASAP. The S23 ULTRA was at par with the iphones for its performance and battery backup, then why removing the crown with a buggy update.
#s23ultra #batterydrain #oneui6batterydrain
66 Comments
Jeevee
Lds
In which setting you got this sot
I get only 6 hour of sot on 0 to 100 percent use. Send setting details
KD91
It's not a good SOT bro. But as far as settings are concerned, they are the default ones, dark mode, 120hz, standard profile, qhd+ resolution
Lds
OK I use same setting wqhd setting apply in resolution
Yes the SOT has been reduced by 1 to 1.5 hrs as this stable update is based on beta 9 which had this issue which I'm hoping samsung fixes it in November patch
Secondly I got this feeling from first beta release that when we use protect battery the battery drain is fast compared to 100% drain I don't know may be im feeling this or others to have this issue when I on protect battery my drop from 85 to 80 it's like on 15 odd minutes it's really creepy but that's what I noticed
KD91
Perfectly said. 85% to 75% gives roughly 25-30 mins SOT. AND 85% to 83% within 2 mins maxm. 🙄
Do you think they will fix these in Nov update ..?
Yeah I guess they should fix this as this issue is very annoying and it overall decimates the whole concept of protect battery as it is draining battery very insanely imagine u charge ur phone to 85 and after 30 mins u find it is already 75😁😁😁😁
KD91
Exactly. 🤣
KD91
But charging everytime to 100% is not good for the battery ryt ?
Jeevee
Not really
But ideally don't get battery to 0% instead charge when it's between 20-30%
