Auto restart problem
(Topic created on: Monday)
subesh23
After recent update ,my phone restart too often and sometimes it gets off for many minutes and never gets and even no charging sign comes when charged in..its frustating to see..after ui 8.5 update..
cs_member10
Dear Samsung Member,
● Clear app cache through Device care:
Settings > Device care > Storage > CLEAN NOW.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
● Kindly restart the device: Press the power and volume down keys simultaneously for a few seconds.
● Kindly remove the current fingerprint and set up the fingerprint again. When you touch the sensor to set up a fingerprint, make sure you set the entire fingerprint, including the outer area of your fingertip. Setting the entire fingerprint area enables successful fingerprint recognition with any grip.
3.If you do not remember password then advise to reset (Forgot password) your Google account.
If the issue still occurs, please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
