Auto call recording for S10 plus
(Topic created on: 05-25-2021 02:16 AM)
Santhoshprasanna
Is there any option for recording the call in S10 plus???
7 Comments
Zatch07
Yes there is. Go to your call settings and turn on automatic record calls. That's it
Prashantbgh
Yes
Follow screenshots
Note: if you are using wifi calling then it won't work 20200608_201647.jpg20200608_201637.jpg20200608_201625.jpg
Check it
But there is no option for enable the call recordings.Screenshot_20210525-104643_Call settings.jpg
From, where(which country)you bought this device?
I bought this mobile in UK.
