Auto Blocker Problem
(Topic created on: 07-16-2025 05:31 PM)
Kabbya_Singha
When i am turning on Auto Blocker i am not able to call any numbers and also can't receive any calls from other. It's showing Connection problem. Does anyone face this kind of issue?
7 Comments
DINKAR_A34_5G
It's not a problem, it's a feature.
Kabbya_Singha
I have been using auto blocker for a long time but never faced this. I know if auto blocker is turned on you can't dial some code to access some settings. But you can't call anyone or receive call if auto blocker is turned on,i don't think that's a feature
Surya230
How long have you been facing this problem?
Kabbya_Singha
From yesterday. I watched some yt videos, i also reset the mobile network settings nothing worked. Then i discovered its because of auto blocker
Surya230
Then you have to turn off Auto Blocker.
Kabbya_Singha
Yeah.
cs_member10
Dear Samsung Member,
As per your query, we would request you to kindly perform the following steps to resolve your issue.
● Disable Auto Blocker: Settings> Security and Privacy> Auto Blocker> Then turn it Off.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
