10-14-2021 12:55 PM in
Galaxy S- Mark as New
10-14-2021 05:58 PM in
10-21-2021 11:10 AM in
Galaxy SDear Samsung Member,
We acknowledge your query and apologize for the same. Please perform the below mentioned steps to resolve the issue:
* Open Samsung member app > Get Help > Interactive check > Choose the phone hardware you want to check and optimize performance(eg. port
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
01-17-2023 02:01 PM in
Galaxy SGive a 'Like' if this solution helps you.
My solution is with respect to S21 Ultra phone. May work wih you too.
First, I tried OnePlus USB type C to 3.5mm adapter + 3.5mm Boya BYM1 lavalier mic. Didn't work. Got to know that OnePlus adapter works only with OnePlus phones.
Then I bought a USB type C lavalier mic. Didn't work. Turned out it wasn't supported either.
Then I bought Samsung genuine USB Type C to 3.5mm adapter to connect my Boya BY M1. It worked, but with hopeless recording quality. The recording volumes weren't consistent and wasn't loud enough either. There was a lot of muffling and attenuation. As a matter of fact, I found there's a considerable quality drop for the earphones too.
Nevertheless, I decided to give a last shot at it by using USB Type C OTG adapter. I purchased a QZ USB 3.1 Type C OTG adapter to connect Maono AU-PM461TR USB condenser microphone. Both purchases were from Amazon India. It worked miraculously. The recording quality is amazing, consistent and lound enough. I can also control the mic gain.
If you dont find the QZ OTG adapter, you can use any other OTG adapter. Generally, there's one small form factor adapter and another with a larger form factor. Go with larger one.
Hope it helps. Have a good time recording. :)
