Audio issue/ Bluetooth bug
(Topic created on: 05-12-2025 11:24 AM)
chuck99
I'm experiencing an issue with my earbuds and smartwatch when making calls. When connected to either device, the person on the other end can't hear me 🗣️. However, I can hear them perfectly fine. This is incredibly frustrating 😠, and I'm looking for solutions. Has anyone else encountered this problem? Any advice would be greatly appreciated! #techhelp #audioissues #smartwatch #earbuds
3 Comments
cs_member10
Dear Samsung Member,
● Reset app preferences: Settings > Apps > More option > Reset App Preferences.
● Kindly try to connect your device with "other devices" and check.
● Clear cache: Settings > Apps > Menu > Show system apps > Search and type "Bluetooth" > Bluetooth > Storage > Clear cache > Clear data > OK.
● The clear cache memory of a particular application: Settings > Apps > Now pick the app that you like to clear off the cache memory > Storage > Clear Cache.
● Reset settings: Settings>General Management>Reset> Reset all settings to their default.
● Reset network settings: Reset Wi-Fi, Bluetooth, and other network settings to their default.
● Update device software (If available): Settings > Software update > Download and install > Checking for software update > Software update available > Download > Downloading updates > Install now.
● You can reset your device by following the steps:
3. If you do not remember the password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tab on Factory data reset to reset your device to its factory default settings. This will erase all data, including files and downloaded apps.
Kindly check the same headphones with another phone or other headphones/ buds with the same mobile, if still facing issues, please visit the service center for a physical inspection of your device and headphones. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
Abhay26003
Bluetooth pairing check krna chahiye
chuck99
The problem is solved, after I updated One UI 7
