10-06-2023 09:36 AM in
Galaxy S- Mark as New
10-06-2023 09:48 AM in
10-06-2023 11:16 AM in
10-06-2023 11:04 PM in
10-07-2023 10:29 AM in
10-06-2023 05:23 PM in
Galaxy SDear Samsung Member,
As per your query, we would request you to kindly perform the following steps to resolve your issue. However we're taking your valuable feedback regarding this, it will be helpful to us in future updates.
Clear Sound Picker data: Settings>>Apps>>Filter and Sort>>Enable "Show system apps">>Ok>>Search Sound Picker>>Tap on storage>> Clear data of Sound Picker.
Clear SoundAlive data: Settings>>Apps>>Filter and Sort>>Enable "Show system apps">>Ok>>Search SoundAliver>>Tap on storage>> Clear data.
Clear Adapt sound data: Settings>>Apps>>Filter and sort>>Enable "Show system apps">>Ok>>Search Adapt Sound>>Tap on storage>>clear data
Reset app preferences: Settings >> Apps >> Three dots (Appearing at the top right corner) >>Reset app preferences >> Reset
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
