Aod battery consumption
(Topic created on: 12-03-2024 09:34 AM)
hellopratik
Is this battery consumption by AOD is normal ? (A34 5G)
Battery usage
12 Comments
Prashantbgh
Not normal
hellopratik
Okay .. i guess I've to disable aod
Wodehouse
Better to switch off. 33-34 % is high with almost no tangible benefit in performance and extending battery life.
If this reply answered your query please mark my reply as "resolved" by clicking 3 vertical dots on top right of my reply. Thank you 😊
KVANA
For me it's okay, I suggest reset your phone
KVANA
And you are using tap to show or always
hellopratik
Always on
KVANA
O think that's why aod using too much battery, try to use tap to show for at least one day, for see how much consumption will take aod
Image is mine last day Uses with tap to show
Tomorrow all day I'll use aod for always, I'll tell you result day after tomorrow 1733221629913_1733221629902_0.jpg
hellopratik
Sounds great. I'll let you know tomorrow about battery usage for my device when aod is set to tap to show
KVANA
Okay deal
