Aod Problem
(Topic created on: 01-27-2024 09:21 PM)
PrashantDBhatt
Recently I Buy S24 ultra. But i noticed that In good lock - Clock face, Aod clock face is not apply, i set many times. It show only lock screen clock face. I don't understand what is the problem, if any have a answer please comment that.
8 Comments
Check roaming clock option and turn it off..also clear cache/data of AOD app
Just give a try
Check it but not working
Aod ka option settings se on hai na?? Tap to show or show as scheduled
Check all options
Also check power saving mode options
Yes all is ok but same problem
Change theme and try
Rathanp
Even im facing the same issue, tried applying on good lock but doesn't work
cs_member10
Dear Samsung Member,
As per your query, we request you to share the log file. This will help us to further investigate and resolve this issue.
To attach the log file: Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Its not about wallpaper its about good lock clock style in not apply, aod always show screen lock clock style.
