09-30-2025 09:59 PM in
Galaxy S- Mark as New
09-30-2025 10:05 PM in
09-30-2025 10:07 PM in
09-30-2025 10:33 PM in
09-30-2025 10:36 PM in
10-01-2025 12:34 AM in
10-01-2025 11:00 AM in
Galaxy SDear Samsung member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
▶ Galaxy device Battery drainage issue: Note: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
▶ Galaxy device camera issue: ● Kindly check the physical condition of your camera lens.
● Use a microfiber cloth or a cleaning wipe to clean the camera lens.
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember the password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.)
10-01-2025 03:41 PM in
10-01-2025 03:42 PM in
