Any improvements after replacing s22 battery?
(Topic created on: 09-29-2024 08:37 PM)
devsg
I want to replace the battery after 2 yrs as my s22 ultra is now more overheating and draining battery like hell I want to ask some questions 1.that after replacing battery has the battery life is significantly improved ?
2. How is s22 ultra heating now after replacing battery?
Please let me know
2 Comments
cs_member8
Dear Samsung Member,
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
Update device software (If Software update available): https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
You can reset your device by following the steps.
In case the issue still occurs, kindly visit the service center and inspect your device with the technical team end, they will provide you with all the information in a better way after inspecting the device physically.
You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
devsg
Done everything thankyou for this automated response samsung
