SpaceTime
11-20-2022 03:45 PM (Last edited 11-20-2022 03:46 PM ) in
Settings > Apps > Special Access > Alarms and Reminders
Here you can remove access for customisation service..
- Tags:
- S22+
3 Comments
Sid_Karna
11-20-2022 03:49 PM in
What are the other tips?
SpaceTime
11-20-2022 04:23 PM in
There are so many tips already on the internet .. that's why I mentioned another tip.. however few more that I know for Samsung are -
1. In device care > background usage limits
Uncheck put unused apps to sleep
If required put apps to sleep manually..
2. Disable Google app if possible..and use less google accounts ..also turn off auto sync if possible..
3. Charge whenever battery goes down to 20% and charge till battery goes to 80% ..however I do charge to 100% once a week.. also if you feel battery is not calibrated then follow method 1 or 2 from this (method 3 is not required now a days)-
https://forum.xda-developers.com/t/guide-samsung-battery-calibration.4221355/
Bonus -
https://forum.xda-developers.com/t/noroot-samsung-galaxy-one-ui-optimization-guide.4376755/
Bonus -
Sid_Karna
11-20-2022 05:46 PM in
