Android 13 OS Level Spatial Audio
(Topic created on: 02-12-2023 01:41 AM)
Ramansa
Google has added support for Spatial Audio in Android 13, and Partner OEMs will need to enable it.
Here is some tech information on the same.  - https://www.geeksforgeeks.org/introduction-to-spatial-audio-in-android-13/
For example, Google has reported that "Spatial Audio" feature will work with any connected headset in Pixel phones on Android 13 latest update. - https://support.google.com/pixelphone/thread/195623748/google-pixel-update-january-2023?hl=en
This means once the feature is enabled at Android Level, it can be used with different headsets.
Samsung must ensure to release this feature as an update so that Headsets/TWS (other than Galaxy) are able to use it from Android perspective.
Many like me use Samsung smartphones but don't use Galaxy TWS or headsets. We look forward to access this important feature for the complete smartphone experience.
4 Comments
Radhajhariya
iamrohitkm
Buy galaxy headsets simple.
Ramansa
And why would I do that - for 1 feature, that is already available as a part of OS?
I already have headsets and costly ones that work with every device I have.
Having the feature enabled on Android solves the purpose - I value the money I earn 🙂
cs_member8
Dear Samsung Member,
Thank you for sharing your concern. We acknowledge your query and apologize for the same. We would request you to register your concern in Samsung Members Application. So, that our concern team gets back to you as soon as possible.
Please follow this path to register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback >Ask question
